Datasheet Texas Instruments TPS7301QP — Даташит
СерияTPS73
МодельTPS7301QP
Стабилизаторы напряжения 500 мА с малым падением напряжения и встроенной функцией сброса задержки 8-PDIP от -40 до 125
Low-Dropout Voltage Regulators With Integrated Delayed Reset Function datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 8 мар 1999
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаTPS7301QP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Точность2 %
Fixed Output Options2.5,3,3.3,4.8,5 В
Iout(Max)0.5 A
Iq(Typ)0.34 мА
Noise74 uVrms
PSRR @ 100KHz8 дБ
Package GroupPDIP
Regulated Outputs1
Special FeaturesEnable,Power Good
Thermal Resistance ОёJA106 В°C/W
Vdo(Typ)270 мВ
Vin(Max)10 В
Vin(Min)2.47 В
Vout(Max)9.75 В
Vout(Min)1.2 В
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7301QP
