Datasheet ТI ADS5271IPFPT — Даташит
| Серия | ADS5271 |
| Модель | ADS5271IPFPT |
Восьмиканальный 12-разрядный аналого-цифровой преобразователь (АЦП) с быстродействием 50 MSPS 80-HTQFP от -40 до 85
8-Channel, 12-Bit, 50MSPS Analog-to-Digital Converter with Serial LVDS Interface datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 6 янв 2009
- Using the ADSDeSer-50EVM to Deserialize ADS527x 10-Bit OutputsPDF, 104 Кб, Файл опубликован: 8 июл 2004
The ADSDeSer-50EVM provides an direct means of examining the serialized 10-bit data output from the ADS527x families of serialized low voltage differential signal(LVDS) data converters by deserializing the data and converting to a parallel data port. This application report discusses the process of reading deserialized 10-bit data outputs from the ADS527x family using the ADSDeSer50-EVM. - LVDS Outputs on the ADS527xPDF, 236 Кб, Файл опубликован: 10 июн 2004
- Interfacing High-Speed LVDS Outputs of the ADS527x/ADS524xPDF, 67 Кб, Файл опубликован: 23 фев 2005
The ADS527x and ADS524x families of devices are high-performance octal/quad channel analog-to-digital converters, ideal for the highest system density. Serial low voltage differential signaling (LVDS) outputs reduce the number of I/O interfaces required, power and overall package size. These device families are rated to work from sampling rates of 20MSPS to 70MSPS, corresponding to data rates of 2 - Interfacing the VCA8613 with High-Speed ADCsPDF, 78 Кб, Файл опубликован: 5 апр 2005
The VCA8613 is an 8-channel variable gain amplifier ideally suited for portable and mid-range ultrasound applications. Each channel consists of a Low Noise Amplifier (LNA) and a Variable Gain Amplifier (VGA). The VGA contains two parts: a voltage-controlled attenuator (VCA) and a programmable gain amplifier (PGA). The PGA output feeds directly into an integrated 2-pole low-pass Butterworth filter. - Interfacing the VCA8617 with High-Speed ADCsPDF, 72 Кб, Файл опубликован: 5 апр 2005
The VCA8617 is an 8-channel variable gain amplifier ideally suited for portable and mid-range ultrasound applications. Each channel consists of a Low Noise Amplifier (LNA) and a Variable Gain Amplifier (VGA). The VGA contains two parts: a voltage-controlled attenuator and a programmable gain amplifier. The PGA output feeds directly into an integrated 3-pole low-pass Butterworth filter, which preve - CDCE62005 as Clock Solution for High-Speed ADCsPDF, 805 Кб, Файл опубликован: 4 сен 2008
TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements - Why Use Oversampling when Undersampling Can Do the Job? (Rev. A)PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 июл 2013
- Design Considerations for Avoiding Timing Errors during High-Speed ADC, LVDS Dat (Rev. A)PDF, 2.0 Мб, Версия: A, Файл опубликован: 22 май 2015
- Smart Selection of ADC/DAC Enables Better Design of Software-Defined RadioPDF, 376 Кб, Файл опубликован: 28 апр 2009
This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs. - Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
Серия: ADS5271 (2)
- ADS5271IPFP ADS5271IPFPT
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
