Datasheet Texas Instruments LM2704MF-ADJ — Даташит
СерияLM2704
МодельLM2704MF-ADJ
Микромощный повышающий преобразователь постоянного тока в постоянный с пределом пикового тока 550 мА 5-SOT-23 от -40 до 85
LM2704 Micropower Step-up DC/DC Converter with 550mA Peak Current Limit datasheet
PDF, 997 Кб, Версия: D, Файл опубликован: 1 май 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
МаркировкаS28B
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Package GroupSOT-23
ТипConverter
RoHSНе совместим
  • Evaluation Modules & Boards: LM2704EV
    Micropower Step-up DC DC Converter with 550mA Peak Current Limit
  • Inductive Based Switch Reg Circuits Provide High Efficiency White LED Drives (Rev. B)
    PDF, 135 Кб, Версия: B, Файл опубликован: 6 май 2013
    White LEDs are quickly becoming the light of choice for backlighting of small color displays because of their falling costs, longer life, and smaller size. The problem this presents is that the white LED has a high voltage drop (3.1 V to 4.0 V depending on manufacturer) as compared to the monochrome displays' green LED with a voltage drop of 1.8 V to 2.7 V. Whereas the green LED can be powered dir
  • Inductive-Based Switch Reg Circuits Provide High-Efficiency White-LED Drvs
    PDF, 160 Кб, Файл опубликован: 29 апр 2002
Серия: LM2704 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
LM2704MFADJ, LM2704MF ADJ
На английском языке: Datasheet Texas Instruments LM2704MF-ADJ
