Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74ACT240NSR — Даташит
СерияSN74ACT240
МодельSN74ACT240NSR
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-SO от -40 до 85
SN54ACT240, SN74ACT240 datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 7 окт 2002
Pin20
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаACT240
Width (мм)5.3
Length (мм)12.6
Thickness (мм)1.95
Max Height (мм)2
Bits8
F @ Nom Voltage(Max)90 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupSO
Package Size: mm2:W x L20SO: 98 mm2: 7.8 x 12.6(SO) PKG
Schmitt TriggerNo
Technology FamilyACT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ACT240NSR
