Datasheet Texas Instruments TXB0101DCKR — Даташит
СерияTXB0101
МодельTXB0101DCKR
1-битный двунаправленный переключатель уровня напряжения с автоматическим определением направления и защитой от электростатического разряда +/-15 кВ 6-SC70 от -40 до 85
TXB0101 1-Bit Bidirectional Level-Shifting and Voltage Translator With Auto Direction-Sensing and В±15-kV ESD Protection datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 13 мар 2017
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
Маркировка27O
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)50 Mhz
Gate TypeN/A
ICC @ Nom Voltage(Max)0.003 мА
LogicTrue
Output Drive (IOL/IOH)(Max)0.02/-0.02 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesOne-Shot Edge Accelerators,Bidirectional
Sub-FamilyDual Supply Translator
Technology FamilyTXB
VCC(Max)5.5 В
VCC(Min)1.2 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.9 нс
  • A Guide to Voltage Translation With TXB-Type Translators
    PDF, 102 Кб, Файл опубликован: 3 мар 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments TXB0101DCKR
