Datasheet Texas Instruments SNJ54AS646JT — Даташит
СерияSN54AS646
МодельSNJ54AS646JT
Восьмеричные шинные трансиверы и регистры с выходами с 3 состояниями, 24-CDIP, от -55 до 125
Octal Bus Transceivers & Registers With 3 -State Outputs datasheet
PDF, 890 Кб, Версия: F, Файл опубликован: 1 янв 1995
Pin2424
Package TypeJTJT
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаSNJ54AS646JT5962-8759501LA
Width (мм)6.926.92
Length (мм)3232
Thickness (мм)4.74.7
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Bits8
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN54AS646 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
На английском языке: Datasheet Texas Instruments SNJ54AS646JT
