Datasheet Texas Instruments REG104FA-2.5/500G3 — Даташит
СерияREG104
МодельREG104FA-2.5/500G3
1А, малошумящий регулятор с малым падением напряжения 5-DDPAK/TO-263
DMOS 1A Low-Dropout Regulator datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 22 сен 2005
IC REG LIN 2.5V 1A DDPAK/TO263-5. Linear Voltage Regulator IC 1 Output 1A DDPAK/TO-263-5. PMIC - Voltage Regulators - Linear
REG104FA-2.5/500G3
329 ₽
Hi-Tech Circuit Group
REG104FA-2.5/500G3
727GS
REG104FA-2.5/500G3
Рутоника
REG104FA-2.5/500G3
Pin55
Package TypeKTTKTT
Industry STD TermTO-263TO-263
JEDEC CodeR-PSFM-GR-PSFM-G
Package QTY500500
CarrierLARGE T&RLARGE T&R
Маркировка104FA-2.5REG
Width (мм)8.428.42
Length (мм)10.1610.16
Thickness (мм)4.584.58
Pitch (мм)1.71.7
Max Height (мм)4.834.83
Accuracy(%)3.5
Approx. Price (US$)2.33 | 1ku
Fixed Output Options(V)2.5
3
3.3
5
Iout(Max)(A)1
Iq(Typ)(mA)1.7
Noise(uVrms)33
Operating Temperature Range(C)-40 to 85
Output Capacitor TypeCap Free
Ceramic
Output OptionsAdjustable Output
Fixed Output
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)5DDPAK/TO-263: 155 mm2: 15.24 x 10.16(DDPAK/TO-263)
Regulated Outputs(#)1
Special FeaturesEnable
Thermal Resistance ОёJA(В°C/W)27
Vdo(Typ)(mV)230
Vin(Max)(V)15
Vin(Min)(V)2.7
Vout(Max)(V)5.5
Vout(Min)(V)1.3
  • Evaluation Modules & Boards: SN65DSI85EVM
    SN65DSI85 Dual-Channel MIPIВ® DSI to Dual-Link FlatLinkв„ў LVDS Bridge Evaluation Module (EVM)
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76XXXEVM-125
    TPS76xxxEVM-125 Universal SOT-23 LDO Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Evaluation Modules & Boards: SN65DSI83EVM
    SN65DSI83 MIPIВ® DSI to FlatLinkв„ў LVDS Bridge Evaluation Module
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG104FA2.5/500G3, REG104FA 2.5/500G3
На английском языке: Datasheet Texas Instruments REG104FA-2.5/500G3
