Datasheet Texas Instruments TPA6166A2YFFT — Даташит
Серия | TPA6166A2 |
Модель | TPA6166A2YFFT |
Усилитель для наушников DirectPath™ класса G с разъемом 3,5 мм и интерфейсом для гарнитуры 25-DSBGA от -40 до 85
TPA6166A2 3.5-mm Jack Detect and Headset Interface IC datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 23 янв 2015
Pin | 25 |
Package Type | YFF |
Industry STD Term | DSBGA |
JEDEC Code | S-XBGA-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | SMB |
Width (мм) | 2.2 |
Length (мм) | 2.2 |
Thickness (мм) | .425 |
Pitch (мм) | .4 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
Analog Supply (V) | 1.9 Min |
Архитектура | Class-G |
Headphone Channels | Stereo |
Iq per channel(Typ) | 1.2 мА |
Load(Min) | 32 ohms |
Выходная мощность | 0.03 W |
PSRR | 92 дБ |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rating | Catalog |
Volume Control | Yes |
- Evaluation Modules & Boards: TPA6166A2YFFEVM
TPA6166A2YFFEVM Headphone Amplifier with Jack Detect Evaluation Module
- Ground Loop Break (GLB) CircuitsPDF, 562 Кб, Файл опубликован: 1 окт 2009
Ground loops can be introduced when different components in audio systems are connected with standardaudio cables, and these loops can cause annoying interference. In many cases, the interference can bereduced significantly with a ground loop break (GLB) circuit including a low-value resistor and differentialamplifiers. This paper explains this approach and how to design a GLB circuit. - Reducing Crosstalk in Directpath Headphone AmplifiersPDF, 74 Кб, Файл опубликован: 28 мар 2012
- PowerWiseГѓВ« Class G versus Class AB Headphone AmplifiersPDF, 371 Кб, Файл опубликован: 11 июн 2009
- A Low-Cost, Single Coupling Capacitor Config. for Stereo Headphone AmplifiersPDF, 110 Кб, Файл опубликован: 22 дек 1999
This application report compares two possible blocking or coupling capacitor configurations for stereo headphone amplifiers operating from a single supply voltage. The report demonstrates that the standard two-capacitor configuration can be replaced by a single-capacitor configuration with little or no perceivable difference in sound quality. The primary advantage of a single-capacitor system is t - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA6166A2 (2)
- TPA6166A2YFFR TPA6166A2YFFT
- Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Headphone Amplifier
