Datasheet Texas Instruments UCC2889DTR/81361G4 — Даташит
| Серия | UCC2889 |
| Модель | UCC2889DTR/81361G4 |
Контроллер автономного источника питания 8-SOIC от -40 до 85
Off-line Power Supply Controller datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 20 фев 2003
Off-line Power Supply Controller 8-SOIC -40 to 85 | |||
| UCC2889DTR/81361G4 Texas Instruments | по запросу | ||
| Статус продукта | Анонсирован (Компонент анонсирован, но еще не запущен в серийное производство. Образцы могут быть как доступны, так и нет) |
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 0.85 | 1ku |
| Control Method | Feedforward Voltage |
| Duty Cycle(Max)(%) | 55 |
| Frequency(Max)(kHz) | 250 |
| Gate Drive(Typ)(A) | 0.2 |
| Operating Temperature Range(C) | -40 to 85 |
| Package Group | SOIC |
| Rating | Catalog |
| Special Features | Error Amplifier Green Mode Light Load Efficiency Soft Start |
| Topology | Flyback |
| UVLO Thresholds On/Off(V) | 8.4/6.3 |
| Vin(Max)(V) | 9.3 |
| Vin(Min)(V) | 8.6 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Evaluation Modules & Boards: UCC3889EVM
UCC3889 Evaluation Module
- DN-59A UCC3889 Bias Supply Controller EVM Kit - SchematicPDF, 144 Кб, Файл опубликован: 5 сен 1999
This design note presents a schematic and a photograph of the top-side layout for the UCC3889 Off-Line Bias Supply Controller IC Evaluation Kit. This board accepts both conventional "through-hole" or leaded components as well as their surface-mount counterparts. An additional prototyping area allows engineers to further customize these units to address their projects' specific needs. Component lis - U-149 Elegantly Simple Off-Line Bias Supply for Very Low Power ApplicationsPDF, 328 Кб, Файл опубликован: 5 сен 1999
The UCC3889 controller is an off-line, low-power, low-voltage, regulated-bias power supply. The unique circuit topology in this device can be visualized as two cascaded flyback converters, each operating in the discontinuous mode, and both driven from a single external power switch. The significant benefit of this approach is voltage conversion ratios of 400V to 12V, with no transformer and low in
Серия: UCC2889 (6)
- UCC2889D UCC2889DG4 UCC2889DTR UCC2889DTR/81361G4 UCC2889DTRG4 UCC2889N
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
