Datasheet ТI 74AC11008PWLE — Даташит
Серия74AC11008
Модель74AC11008PWLE
Datasheet Texas Instruments 74AC11008PWLE
Четверные логические элементы положительного И с 2 входами 16-TSSOP от -40 до 85
Quadruple 2-Input Positive-AND Gate datasheet
PDF, 867 Кб, Версия: C, Файл опубликован: 1 апр 1996
  • Live Insertion
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments 74AC11008PWLE
Политика конфиденциальности
