Datasheet Texas Instruments LM2748MTC/NOPB — Даташит
СерияLM2748
МодельLM2748MTC/NOPB
1–14 В, синхронный понижающий контроллер в режиме напряжения с запуском до смещения 14-TSSOP от -40 до 125
LM2745/48 Synch Buck Controller w/ Pre-Bias Startup & Optional Clk Synch datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 3 апр 2013
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9494
CarrierTUBETUBE
Маркировка2748MTC
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeVoltage Mode
Duty Cycle(Max)86 %
Iout(Max)20 A
Iq(Typ)1.7 мА
Number of Phases1
Package GroupTSSOP
Regulated Outputs1
Special FeaturesEnable,Power Good,Synchronous Rectification,Tracking
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)14 В
Vin(Min)1 В
Vout(Max)12 В
Vout(Min)0.6 В
  • Analyzing Power Modules
    PDF, 503 Кб, Файл опубликован: 22 мар 2007
  • AN-1603 LM274X Reference Designs (Rev. C)
    PDF, 222 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application note presents several reference designs that implement the LM274X synchronous buckcontroller. The designs address various applications in a wide variety of configurations. The designreference will give an engineer a head start on their project, with designs encompassing sequencing,tracking, synchronizing multiple power supplies, DDR termination, buck-boost, low PCB real esta
  • Current Limit Foldback Improves Short Circuit Protection in LM274X Family (Rev. B)
    PDF, 89 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report discusses the function of the low side current limit used in the LM274X, andpresents a simple method to enhance the short-circuit protection. the current limit is required to protect thepower components from thermal stress, which can reduce life span. Typically, high side current limitdesigns require an internal rising edge blanking time or external filter to avoid no
  • Optmiz Pwr Cntrlr Dsigns thru Utiliz Freq & Sync, Ext Ref, Trking & Precis EN
    PDF, 359 Кб, Файл опубликован: 24 апр 2008
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM2748 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM2748MTC/NOPB
