Datasheet Texas Instruments OPA1612AQDRQ1 — Даташит
СерияOPA1612-Q1
МодельOPA1612AQDRQ1
Automotive, 1.1nV/в€љHz Noise, Low Power, Precision Audio Operational Amplifier 8-SOIC -40 to 125
OPA1612-Q1 SoundPlus High-Performance, Bipolar-Input Audio Operational Amplifier datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 17 ноя 2015
Package TypeD
Package QTY2500
Маркировка1612Q1
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)110 дБ
CMRR(Typ)120 дБ
GBW(Typ)40 МГц
Input Bias Current(Max)250000 pA
Iq per channel(Max)4.5 мА
Iq per channel(Typ)3.6 мА
Количество каналов2
Offset Drift(Typ)1 uV/C
Output Current(Typ)55 мА
Rail-to-RailOut
RatingAutomotive
Slew Rate(Typ)27 V/us
Total Supply Voltage(Min)4.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Feedback Plots Define Op Amp AC Performance
    PDF, 89 Кб, Файл опубликован: 27 сен 2000
    Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA1612-Q1 (1)
  • OPA1612AQDRQ1
На английском языке: Datasheet Texas Instruments OPA1612AQDRQ1
Публикации по теме
