Datasheet Texas Instruments LM75AIM/NOPB — Даташит
| Серия | LM75A |
| Модель | LM75AIM/NOPB |
В±2В°C Industry Standard Temperature Sensor with I2C/SMBus Interface 8-SOIC -55 to 125
LM75A Digital Temperature Sensor and Thermal Watchdog With Two-Wire Interface datasheet
PDF, 1.2 Мб, Версия: P, Файл опубликован: 30 дек 2014
Купить LM75AIM/NOPB на РадиоЛоцман.Цены — от 21 до 235 ₽43 предложений от 16 поставщиков SENSOR DIGITAL -55C-125C 8SOIC. Temperature Sensor Digital, Local -55°C ~ 125°C 8 b 8-SOIC. Temperature Sensors - Analog and Digital Output... | |||
| LM75AIM/NOPB National Semiconductor | 81 ₽ | ||
| LM75AIM/NOPB Texas Instruments | 159 ₽ | ||
| LM75AIM/NOPB Texas Instruments | от 235 ₽ | ||
| LM75AIM/NOPB Texas Instruments | по запросу | ||
| Pin | 8 | 8 |
| Package Type | D | D |
| Industry STD Term | SOIC | SOIC |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 95 | 95 |
| Carrier | TUBE | TUBE |
| Маркировка | LM75 | AIM |
| Width (мм) | 3.91 | 3.91 |
| Length (мм) | 4.9 | 4.9 |
| Thickness (мм) | 1.58 | 1.58 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 1.75 | 1.75 |
| Addresses | 8 |
| Interface | I2C, SMBus, 2-Wire |
| Iq(Typ) | 280 uA |
| Local Sensor Accuracy(Max) | 2 +/- C |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rating | Catalog |
| Special Features | Programmable Alert,Fault Queue |
| Supply Current(Max) | 500 uA |
| Supply Current(Typ) | 280 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2.7 В |
| Temp Resolution(Max) | 9 bits |
- Temperature sensors: PCB guidelines for surface mount devices (Rev. A)PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo - Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor. - Sensing and Monitoring for Control and Protection SeminarPDF, 245 Кб, Файл опубликован: 17 фев 2003
- Tiny Temperature Sensors for Remote SystemsPDF, 156 Кб, Файл опубликован: 17 фев 2003
- AN-1155 A Simple Software I2C Routine for the COP8PDF, 121 Кб, Файл опубликован: 15 май 2004
Application Note 1155 A Simple Software I2C Routine for the COP8
Серия: LM75A (5)
- LM75AIM/NOPB LM75AIMM/NOPB LM75AIMME/NOPB LM75AIMMX/NOPB LM75AIMX/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
