Datasheet Texas Instruments SN74ACT240DWRE4 — Даташит
СерияSN74ACT240
МодельSN74ACT240DWRE4
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-SOIC от -40 до 85
SN54ACT240, SN74ACT240 datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 7 окт 2002
IC BUFFER INVERT 5.5V 20SOIC. Buffer, Inverting 2 Element 4 Bit per Element 3-State Output 20-SOIC. Logic - Buffers, Drivers, Receivers,...
SN74ACT240DWRE4
15 ₽
Рутоника
SN74ACT240DWRE4
21 ₽
SN74ACT240DWRE4
31 ₽
Hi-Tech Circuit Group
SN74ACT240DWRE4
Pin20
Package TypeDW
Package QTY2000
МаркировкаACT240
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Bits8
F @ Nom Voltage(Max)90 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Schmitt TriggerNo
Technology FamilyACT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ACT240DWRE4
