Datasheet Texas Instruments TS5A4597DCKR — Даташит
Серия | TS5A4597 |
Модель | TS5A4597DCKR |
Одноканальный аналоговый переключатель SPST 8 Ом 5-SC70 от -40 до 85
![]() 39 предложений от 19 поставщиков Интегральные микросхемы Интерфейсы и стыки — аналоговые переключатели, (де)мультиплексоры | |||
TS5A4597DCKR Texas Instruments | 9.64 ₽ | ||
TS5A4597DCKRE4 Texas Instruments | 12 ₽ | ||
TS5A4597DCKR Texas Instruments | 18 ₽ | ||
TS5A4597DCKRE4 Texas Instruments | по запросу |
Pin | 5 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | JVR |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Полоса частот | 450 МГц |
Bandwidth(Max) | 450 МГц |
Configuration | 1:1 SPST |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 20 мА |
Input/Output OFF-state Capacitance(Typ) | 6.5 пФ |
Input/Output ON-state Capacitance(Typ) | 13 пФ |
Количество каналов | 1 |
OFF-state leakage current(Max) | 0.005 мкА |
ON-state leakage current(Max) | 0.01 мкА |
Package Group | SC70 |
Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rating | Catalog |
Ron(Max) | 20 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 50 uA |
Supply Current(Typ) | 0.01 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 2.7 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A4597 (5)
- TS5A4597DBVR TS5A4597DBVRG4 TS5A4597DCKR TS5A4597DCKRE4 TS5A4597DCKRG4
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
