Datasheet Texas Instruments UC1852J — Даташит
СерияUC1852
МодельUC1852J
Пререгулятор с высоким коэффициентом мощности 8-CDIP от -55 до 125
Datasheet
TSP
Package TypeJ
RoHSНе совместим
  • U-132 Power Factor Correction Using UC3852 Controlled On-Time Zero Current
    PDF, 323 Кб, Файл опубликован: 5 сен 1999
    The UC3852 provides a low-cost solution to active power-factor correction (PFC) for systems that would otherwise draw high peak current pulses from AC power lines. This circuit implements zero-current switched boost conversion, producing sinusoidal input currents with a minimum of external components, while keeping peak current substantially below that of fully-discontinuous converters. The contro
Серия: UC1852 (2)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1852J
