Datasheet Texas Instruments TPS6735IDR — Даташит
СерияTPS6735
МодельTPS6735IDR
Инвертирующий преобразователь постоянного тока в постоянный ток с фиксированным отрицательным напряжением 5 В, 200 мА, 8-SOIC, от -40 до 85
Fixed Negative 5-V 200-mA Inverting DC/DC Converter datasheet
PDF, 360 Кб, Версия: A, Файл опубликован: 20 дек 1996
Package TypeD
Package QTY2500
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Duty Cycle(Max)100 %
Основные особенностиEnable
Iq(Typ)1.9 мА
Switch Current Limit(Min)0.2 A
Switch Current Limit(Typ)2 A
Switching Frequency(Max)160 kHz
Switching Frequency(Min)160 kHz
TopologyInverting
ТипConverter
Vin(Max)6.2 В
Vin(Min)4 В
Vout(Max)-5 В
Vout(Min)-5 В
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS6735 (6)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS6735IDR
