Оптопары и оптореле Megawin
Datasheet Texas Instruments LM5015MHE/NOPB — Даташит
СерияLM5015
МодельLM5015MHE/NOPB
4,25–75 В, монолитный двухпереключательный регулятор постоянного тока прямого действия 14-HTSSOP от -40 до 125
LM5015 High Voltage Monolithic Two-Switch Forward DC-DC Regulator datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 29 мар 2013
Pin1414
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаMHLM5015
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Iout1.4 A
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Soft StartAdjustable
Special FeaturesEnable,Frequency Synchronization
Switching Frequency(Max)750 kHz
Switching Frequency(Min)200 kHz
TopologyForward
ТипConverter (Integrated Switch)
Vin(Max)75 В
Vin(Min)4.25 В
Vout(Max)37 В
Vout(Min)1.26 В
  • Evaluation Modules & Boards: LM5015ISOEVAL
    High Voltage Monolithic Two-Switch Forward Isolated DC-DC Converter Evaluation Board
  • Evaluation Modules & Boards: LM5015NISOEVAL
    High Voltage Monolithic Two-Switch Forward DC-DC Converter Evaluation Board
  • Improving the Performance of Traditional Flyback-Topology With Two-Switch –Appro
    PDF, 484 Кб, Файл опубликован: 22 июл 2014
    This application note explains the basic operation of the two-switch Flyback-power stage, and clarifies benefits and design restrictions not present in traditional Flyback-topology. Power stage operation is demonstrated with reference design PMP10037, implemented around a LM5015 High Voltage Monolithic Two-switch DC-DC Regulator. The reference design is available from the TI Po
Серия: LM5015 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Isolated DC/DC Converter
На английском языке: Datasheet Texas Instruments LM5015MHE/NOPB
