Datasheet Texas Instruments TPS61097-33DBVT — Даташит
СерияTPS61097-33
МодельTPS61097-33DBVT
Повышающий преобразователь 0,9 В, выход 3,3 В с байпасным переключателем — ток отключения 5 нА, SOT-23 5-SOT-23 от -40 до 85
Low Input Voltage Synchronous Boost Converter With Low-Quiescent Current datasheet
PDF, 2.1 Мб, Версия: C, Файл опубликован: 6 янв 2012
32 предложений от 17 поставщиков
TPS61097-33DBVT
69 ₽
Зенер
Россия и страны ТС
TPS61097-33DBVT
от 142 ₽
Hi-Tech Circuit Group
TPS61097-33DBVT
TPS61097-33DBVT
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаNFSK
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Рекомендуемая замена
ReplacementTPS61097A-33DBVT
Replacement CodeS
  • Evaluation Modules & Boards: TPS61097-33EVM-498
    TPS61097-33EVM-498 Evaluation Module
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Boost DC/DC with Ultra-Low Shutdown Current (Rev. A)
    PDF, 121 Кб, Версия: A, Файл опубликован: 14 июн 2010
    This reference design is presented to help application designers and others who are trying to use the MSP430 in a system that requires a very low input voltage range while also maintaining high efficiency. Battery life is extended as well as a result of the low quiescent current (5 mA) and ultra-low shutdown current (5 nA) of the TPS61097-33. This particular design allows for an input voltage betw
Серия: TPS61097-33 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
TPS6109733DBVT, TPS61097 33DBVT
На английском языке: Datasheet Texas Instruments TPS61097-33DBVT
