Datasheet Texas Instruments TPS61090RSARG4 — Даташит
СерияTPS61090
МодельTPS61090RSARG4
Переключатель 2 А, повышающий преобразователь с КПД 96 % 16-QFN от -40 до 85
TPS6109x Synchronous Boost Converter With 2-A Switch datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 24 дек 2014
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаTPS61090
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Duty Cycle(Max)100 %
Iq(Typ)0.02 мА
Package GroupQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Load Disconnect,Power Good
Switch Current Limit(Min)2 A
Switch Current Limit(Typ)2 A
Switching Frequency(Max)700 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout(Max)5.5 В
Vout(Min)1.8 В
  • Evaluation Modules & Boards: TPS61090EVM-029
    TPS61090 Evaluation Module
  • Evaluation Modules & Boards: TPS61070EVM-062
    TPS61070 Evaluation Module
  • Powering a White LED Flashlight with the TPS61090
    PDF, 74 Кб, Файл опубликован: 23 май 2005
    This application report details how to drive a 3-W white LED from a single lithium-ion battery using the Texas Instruments TPS61090 low-power dc-dc boost converter to achieve efficiencies >90%. Design considerations and equations needed for driving a single, multiple-watt white LED are covered including efficiency improvements, peak switch current calculations, and a soft-start considerations.
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS61090 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61090RSARG4
