Datasheet Texas Instruments MPA4609IPFBRG4 — Даташит
Серия | MPA4609 |
Модель | MPA4609IPFBRG4 |
Четырехканальный, дифференциальный вход/выход, мультиплексирование 2X1, предусилитель с высоким коэффициентом усиления 48-TQFP от 0 до 70
Pin | 48 |
Package Type | PFB |
Industry STD Term | TQFP |
JEDEC Code | S-PQFP-G |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- RLC Filter Design for ADC Interface Applications (Rev. A)PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD - Measuring Board Parasitics in High-Speed Analog DesignPDF, 134 Кб, Файл опубликован: 7 июл 2003
Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
Серия: MPA4609 (2)
- MPA4609IPFBR MPA4609IPFBRG4
- Semiconductors > Switches and Multiplexers > Multiplexer
