Datasheet Texas Instruments UC1823L — Даташит
СерияUC1823
МодельUC1823L
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 5 авг 2009
Микросхема Контроллер PWM, Current Mode PWM Controller 1.5A 1000kHz 20Pin CLLCC Tube
UC1823L
4 641 ₽
МосЧип
UC1823L/883BC
LifeElectronics
UC1823L/883
UC1823L883B
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
МаркировкаUC1823L
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Control MethodCurrent
Duty Cycle(Max)80 %
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)8.4 В
RoHSSee ti.com
  • U-131 Simple Switchmode Lead-Acid Battery Charger
    PDF, 206 Кб, Файл опубликован: 5 сен 1999
    Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1823L
