Datasheet Texas Instruments LMV981MG — Даташит
СерияLMV981-N
МодельLMV981MG
Одиночные операционные усилители RRIO 1,8 В с отключением 6-SC70 от -40 до 125
LMV98x-N Small, Low-Power, 1.8-V RRIO Operational Amplifiers With Shutdown datasheet
PDF, 1.6 Мб, Версия: M, Файл опубликован: 30 сен 2016
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY1000
МаркировкаA77
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Рекомендуемая замена
ReplacementLMV981MG/NOPB
Replacement CodeS
Additional FeaturesShutdown
Approx. Price (US$)0.36 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)60
CMRR(Typ)(dB)86
GBW(Typ)(MHz)1.5
Input Bias Current(Max)(pA)35000
Iq per channel(Max)(mA)0.23
Iq per channel(Typ)(mA)0.116
Number of Channels(#)1
Offset Drift(Typ)(uV/C)5.5
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)65
Package GroupSC70
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)0.42
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)1.8
Vn at 1kHz(Typ)(nV/rtHz)50
Vos (Offset Voltage @ 25C)(Max)(mV)4
RoHSTBD
  • AN-1684 Saving Power in an AC-Coupled Amplifier Circuit (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 26 апр 2013
    AC-coupled circuits are often used for single supply operation to bring the input voltage into the inputrange of the amplifier. This circuit topology can be used in AC smoke detectors or in AC proximitysensors.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMV981MG
