Datasheet ТI TPA3101D2RGZR — Даташит
| Серия | TPA3101D2 |
| Модель | TPA3101D2RGZR |
Стереоусилитель мощности звука класса D, 10 Вт (TPA3101) 48-VQFN от -40 до 85
10W Stereo Class-D Audio Power Amp datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 19 авг 2010
- TPA3101D2 Mono Amplifier ConfigurationPDF, 74 Кб, Файл опубликован: 17 апр 2006
This application report presents the configuration of the TPA3101D2 as a mono amplifier. - TPA3100D2 Mono Amplifier Configuration (Rev. A)PDF, 117 Кб, Версия: A, Файл опубликован: 16 апр 2007
- Interfacing External Devices to the TPA310xDx AmplifiersPDF, 105 Кб, Файл опубликован: 29 сен 2008
TPA310xDx Logic Pin Interface - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3101D2 (5)
- TPA3101D2PHP TPA3101D2PHPG4 TPA3101D2PHPR TPA3101D2RGZR TPA3101D2RGZT
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
