Datasheet Texas Instruments TPS61014DGSR — Даташит
СерияTPS61014
МодельTPS61014DGSR
Синхронный повышающий преобразователь с низким входным напряжением и фиксированным выходным напряжением 2,8 В, 10-VSSOP от -40 до 85
TPS6101x High-Efficiency, 1-Cell and 2-Cell Boost Converters datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 4 авг 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаAIT
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Approx. Price (US$)1.32 | 1ku
Duty Cycle(Max)(%)100
Iq(Typ)(mA)0.05
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Light Load Efficiency
Output Discharge
Power Good
Switch Current Limit(Min)(A)0.95
Switch Current Limit(Typ)(A)1.01
Switching Frequency(Max)(kHz)780
Switching Frequency(Min)(kHz)420
ТипConverter
Vin(Max)(V)2.8
Vin(Min)(V)0.8
Vout(Max)(V)2.8
Vout(Min)(V)2.8
  • Evaluation Modules & Boards: TPS61016EVM-157
    Fixed 3.3-V High-Efficiency Boost Converter
  • Evaluation Modules & Boards: TPS61015EVM-157
    Fixed 3.0-V High-Efficiency Boost Converter
  • Factors That Determine Light Load PSM Switching Frequncy for TPS6101X Boost Conv
    PDF, 183 Кб, Файл опубликован: 6 дек 2006
    This application report explains the factors that determine the low output power switching frequencies when using the TPS6101x step-up converters.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61014 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61014DGSR
