Datasheet Texas Instruments LMT90DBZT — Даташит
СерияLMT90
МодельLMT90DBZT
Positive +10.0mV/В°C Gain Analog Output Temperature Sensor 3-SOT-23 -40 to 125
LMT90 SOT-23 Single-Supply Centigrade Temperature Sensor datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 29 сен 2015
Pin3
Package TypeDBZ
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаT8C
Width (мм)1.3
Length (мм)2.92
Thickness (мм)1
Pitch (мм).96
Max Height (мм)1.22
InterfaceAnalog Output
Local Sensor Accuracy(Max)4 +/- C
Output Impedance2000 Ohm
Package GroupSOT-23
Package Size: mm2:W x L3SOT-23: 4 mm2: 1.3 x 2.92(SOT-23) PKG
Sensor Gain10 mV/Deg C
Special FeaturesIndustry standard pinout
Supply Current(Max)130 uA
Supply Voltage(Max)10 В
Supply Voltage(Min)4.5 В
  • Evaluation Modules & Boards: LMT90EVM
    LMT90EVM Temperature Sensor EVM
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT90 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT90DBZT
