Datasheet Texas Instruments TRF3761-CIRHATG4 — Даташит
| Серия | TRF3761-C |
| Модель | TRF3761-CIRHATG4 |
Малошумный синтезатор частоты PLL целого числа n со встроенным ГУН 40-VQFN от -40 до 85
TRF3761-x Integer-N PLL with Integrated VCO datasheet
PDF, 2.5 Мб, Версия: K, Файл опубликован: 31 дек 2015
Купить TRF3761-CIRHATG4 на РадиоЛоцман.Цены — от 322 до 970 ₽8 предложений от 8 поставщиков Микросхема Тактовый генератор, Clock Generator 10MHz to 104MHz Input 40Pin VQFN EP T/R | |||
| TRF3761-CIRHATG4 Texas Instruments | 322 ₽ | ||
| TRF3761-CIRHATG4 Texas Instruments | 573 ₽ | ||
| TRF3761-CIRHATG4 Texas Instruments | 919 ₽ | ||
| TRF3761-CIRHATG4 Texas Instruments | по запросу | ||
| Pin | 40 | 40 |
| Package Type | RHA | RHA |
| Industry STD Term | VQFN | VQFN |
| JEDEC Code | S-PQFP-N | S-PQFP-N |
| Package QTY | 250 | 250 |
| Carrier | SMALL T&R | SMALL T&R |
| Маркировка | -C | TRF3761 |
| Width (мм) | 6 | 6 |
| Length (мм) | 6 | 6 |
| Thickness (мм) | .9 | .9 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1 | 1 |
| Current Consumption | 130 мА |
| Integrated VCO | Yes |
| Lock Time(Typ) | >350 us |
| Normalized PLL Phase Noise | -137 dBc/Hz |
| Output Frequency(Max) | 1790 МГц |
| Output Frequency(Min) | 1660 МГц |
| Package Size: mm2:W x L | 40VQFN: 36 mm2: 6 x 6(VQFN) PKG |
| Rating | Catalog |
| Special Features | Integrated VCO |
| VCC | 4.5 to 5.25 В |
| VCO Phase Noise(Nom) | -136 dBc/Hz |
- TRF3761 QFN Installation Using a Hakko Hot Air Rework StationPDF, 38 Кб, Файл опубликован: 7 апр 2007
The TRF3761 devices are typically sampled separately from the board provided. This guideline is designed to help the user evaluating these parts install the sample device. - Fractional/Integer-N PLL BasicsPDF, 6.7 Мб, Файл опубликован: 13 май 1998
Phase Locked Loop (PLL) is a fundamental part of radio, wireless and telecommunication technology. The goal of this document is to review the theory, design and analysis of PLL circuits. PLL is a simple negative feedback architecture that allows economic multiplication of crystal frequencies by large variable numbers. By studying the loop components and their reaction to various noise sources, we
Серия: TRF3761-C (2)
- TRF3761-CIRHAT TRF3761-CIRHATG4
- Semiconductors > Clock and Timing > RF PLLs and Synthesizers
TRF3761CIRHATG4, TRF3761 CIRHATG4
