Datasheet Texas Instruments JM38510/38302BRA — Даташит
Серия | SN54ALS241C |
Модель | JM38510/38302BRA |
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-CDIP от -55 до 125
Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 1 авг 1995
Pin | 20 | 20 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 38302BRA | JM38510/ |
Width (мм) | 6.92 | 6.92 |
Length (мм) | 24.2 | 24.2 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 8 |
Тип входа | TTL |
Тип выхода | TTL |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ALS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
RoHS | See ti.com |
- Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
This document introduces the advanced Schottky family of clamped TTL integrated circuits (ICs). Detailed electrical characteristics of the 'AS and 'ALS devices with table formats are provided. Guidelines for designing high-performance digital systems using the Advanced Schottky family are given along with a brief summary of the solutions to most design decisions needed to implement systems using t - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
Серия: SN54ALS241C (5)
- JM38510/38302BRA M38510/38302BRA SN54ALS241CJ SNJ54ALS241CFK SNJ54ALS241CJ
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
