Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74AS253ANE4 — Даташит
СерияSN74AS253A
МодельSN74AS253ANE4
Двойные селекторы/мультиплексоры данных 1 из 4 с выходами с 3 состояниями 16-PDIP от 0 до 70
Dual 1-of-4 Data Selectors/Multiplexers With 3-State Outputs datasheet
PDF, 728 Кб, Версия: A, Файл опубликован: 1 дек 1994
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)2.47 | 1ku
Bandwidth(MHz)125
Bits(#)4
Channels(#)2
Configuration4:1
Digital input leakage(Max)(uA)5
ESD Charged Device Model(kV)0.75
ESD HBM(kV)2
F @ Nom Voltage(Max)(Mhz)125
FunctionEncoder/Multiplexer
ICC @ Nom Voltage(Max)(mA)14
Output Drive (IOL/IOH)(Max)(mA)24/-2.6
Package GroupPDIP
Schmitt TriggerNo
Technology FamilyAS
Тип3-State Output
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)21
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN74AS253A (4)
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74AS253ANE4
