Datasheet Texas Instruments TS5V522CDBQR — Даташит
СерияTS5V522C
МодельTS5V522CDBQR
ПЕРЕКЛЮЧАТЕЛЬ ВИДЕООБМЕНА 5 В, 5 БИТ ДЛЯ ДВОЙНОГО ИСТОЧНИКА VGA НА ПРИЕМНИК 24-SSOP От -40 до 85
5V, 5-BITS VIDEO EXCHANGE SWITCH FOR DUAL VGA SOURCE TO SINK, TS5V522C datasheet
PDF, 877 Кб, Файл опубликован: 29 мар 2011
Pin24
Package TypeDBQ
Industry STD TermSSOP
Package QTY2500
МаркировкаTS5V522C
Width (мм)3.9
Length (мм)8.65
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Additional FeaturesLow Power,IOFF
Полоса частот380 МГц
CrosstalkYes дБ
ESD Charged Device Model1 kV
ESD HBM2 kV
ICC(Max)3 uA
Input/Output Continuous Current(Max)128 мА
Количество каналов5
Package GroupSSOP
Package Size: mm2:W x L24SSOP: 52 mm2: 6 x 8.65(SSOP) PKG
Ron(Max)7 Ohms
Ron(Typ)3 Ohms
VCC(Max)5.5 В
VCC(Min)4 В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5V522C (2)
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS5V522CDBQR
