Datasheet Texas Instruments LM3445MMX/NOPB — Даташит
СерияLM3445
МодельLM3445MMX/NOPB
Автономный светодиодный драйвер триака с регулируемой яркостью 10-VSSOP от -40 до 125
LM3445 TRIAC Dimmable Offline LED Driver datasheet
PDF, 1.2 Мб, Версия: M, Файл опубликован: 30 ноя 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY3500
МаркировкаSULB
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Dimming MethodForward Phase (Triac),PWM,Reverse Phase
Входное напряжениеAC/DC Type
Iout(Max)2 A
Iq(Typ)2 мА
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Power Factor CorrectionActive,Passive Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)30 kHz
TopologyBuck,Flyback
ТипInductive
Vin(Max)12 В
Vin(Min)8 В
Vout(Max)60 В
Vout(Min)9 В
Vref0.75 В
  • Evaluation Modules & Boards: LM3445-230VFLBK
    230VFLBK-LM3445 evaluation board optimized for 230V input isolated applications
  • Evaluation Modules & Boards: LM3445-EDSNEV
    EDSNEV- 10W, non-isolated LM3445 evaluation board optimized for small solution size
  • Evaluation Modules & Boards: LM3445-120VFLBK
    120VFLBK-LM3445 evaluation board optimized for 120V input isolated applications
  • Evaluation Modules & Boards: LM3445EVM-695
    LM3445 120Vac Valley Fill Buck Triac Dimmable LED Driver Evaluation Module
  • An Improved Line Regulation Solution Used in LM3444/5 Non-Isolated LED Lighting
    PDF, 1.0 Мб, Файл опубликован: 25 окт 2012
  • AN-2034 LM3445 -120VAC, 8W Isolated Flyback LED Driver (Rev. C)
    PDF, 24.5 Мб, Версия: C, Файл опубликован: 1 май 2013
    This demonstration board highlights the performance of a LM3445 based Flyback LED driver solution that can be used to power a single LED string consisting of 4 to 8 series connected LEDs from an 90 VRMS to 135 VRMS, 60 Hz input power supply. The key performance characteristics under typical operating conditions are summarized in this application report.
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • AN-2069 LM3445 - 230VAC, 6W- 15W Isolated Flyback LED Driver (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 23 ноя 2010
    Application Note 2069 LM3445 - 230VAC, 6W- 15W Isolated Flyback LED Driver
Серия: LM3445 (4)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3445MMX/NOPB
