Datasheet Texas Instruments TXS0102DCTRE4 — Даташит
СерияTXS0102
МодельTXS0102DCTRE4
2-битный двунаправленный преобразователь уровня напряжения для приложений с открытым стоком и двухтактной схемы 8-SM8 от -40 до 85
TXS0102 2-Bit Bidirectional Voltage-Level Translator for Open-Drain and Push-Pull Applications datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 3 фев 2016
Pin88
Package TypeDCTDCT
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаZNFE
Width (мм)2.82.8
Length (мм)2.952.95
Thickness (мм)1.291.29
Pitch (мм).65.65
Max Height (мм)1.31.3
3-State OutputNo
Bits2
F @ Nom Voltage(Max)12 Mhz
Gate TypeN/A
ICC @ Nom Voltage(Max)0.012 мА
LogicTrue
Output Drive (IOL/IOH)(Max)1/-.02 мА
Package GroupSM8
Package Size: mm2:W x L8SM8: 12 mm2: 4 x 2.95(SM8) PKG
Schmitt TriggerNo
Special FeaturesOne-Shot Edge Accelerators,Bidirectional
Sub-FamilyDual Supply Translator
Technology FamilyTXS
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.2 нс
  • Evaluation Modules & Boards: SN65DSI83EVM
    SN65DSI83 MIPIВ® DSI to FlatLinkВ™ LVDS Bridge Evaluation Module
  • Evaluation Modules & Boards: SN65DSI85EVM
    SN65DSI85 Dual-Channel MIPIВ® DSI to Dual-Link FlatLinkВ™ LVDS Bridge Evaluation Module
  • Evaluation Modules & Boards: SN65DSI85Q1-EVM
  • Evaluation Modules & Boards: SN65DSI83Q1-EVM
  • Development Kits: DLPLIGHTCRAFTER
    DLPВ® LightCrafterВ™ Evaluation Module
  • Evaluation Modules & Boards: DLPDLCR4710EVM-G2
    Full HD DLP4710 Chipset Evaluation Module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterВ™ 4500
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments TXS0102DCTRE4
