Datasheet Texas Instruments ADS7865IPBSR — Даташит
СерияADS7865
МодельADS7865IPBSR
Двойной, 2MSPS, 12-битный, 3+3 или 2+2-канальный АЦП с одновременной выборкой 32-TQFP от -40 до 125
Dual, 12-Bit, 3+3 or 2+2 Channel, Simultaneous Sampling ADC datasheet
PDF, 780 Кб, Версия: C, Файл опубликован: 17 апр 2012
Pin32
Package TypePBS
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
Маркировка7865I A
Width (мм)5
Length (мм)5
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# Input Channels6
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Pseudo-Differential
Integrated FeaturesN/A
InterfaceParallel
Package GroupTQFP
Package Size: mm2:W x L32TQFP: 49 mm2: 7 x 7(TQFP) PKG
Power Consumption(Typ)30 mW
Reference ModeExt,Int
Разрешение12 Bits
SINAD71.3 дБ
SNR71.7 дБ
Sample Rate (max)2MSPS SPS
Sample Rate(Max)2 MSPS
THD(Typ)-87 дБ
  • Interfacing the ADS786x to the MSP430F2013
    PDF, 90 Кб, Файл опубликован: 15 июн 2006
    This application report presents methods of interfacing the ADS7866/67/68 12/10/8-bit SAR analog-to-digital converter to the MSP430F2013 universal serial interface (USI) in SPI mode. The flexible clocking scheme of the USI port, along with the internal 16-bit shift register, provides an easy hardware/software interface to this series of high-speed, micro-power SAR converters.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7865 (3)
На английском языке: Datasheet Texas Instruments ADS7865IPBSR
