Datasheet Texas Instruments TCA9546ADR — Даташит
СерияTCA9546A
МодельTCA9546ADR
1,65–5,5 В, 4-канальный переключатель I2C и SMBus с функцией сброса, 16-SOIC от -40 до 85
TCA9546A Low Voltage 4-Channel I2C and SMBus Switch with Reset Function datasheet
PDF, 939 Кб, Версия: A, Файл опубликован: 16 фев 2015
Pin16
Package TypeD
Package QTY2500
МаркировкаTCA9546A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Channel Width4
I2C Address1110 xxx
Simultaneously Active Channels1 to 4
Special FeaturesReset Input,5V Tolerant I/O
VCC(Max)5.5 В
VCC(Min)1.65 В
fSCLK(Max)0.4 МГц
tpd max1 нс
  • Evaluation Modules & Boards: TCA9548AEVM
    TCA9548AEVM: I2C 1-to-8 Bidirectional Translating Switch Evaluation Module
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA9546A (2)
  • Semiconductors > Interface > I2C > I2C Switches and Multiplexers
На английском языке: Datasheet Texas Instruments TCA9546ADR
