Datasheet Texas Instruments SN65LBC184PE4 — Даташит
| Серия | SN65LBC184 |
| Модель | SN65LBC184PE4 |
Приемопередатчик RS-485 со встроенным подавлением переходных напряжений 8-PDIP от -40 до 85
SNx5LBC184 Differential Transceiver With Transient Voltage Suppression datasheet
PDF, 1.1 Мб, Версия: I, Файл опубликован: 30 июн 2015
Купить SN65LBC184PE4 на РадиоЛоцман.Цены — от 131 до 237 ₽10 предложений от 10 поставщиков Чип интерфейса, RS-485 Transceiver with Integrated Transient Voltage Suppression 8-PDIP -40℃ to 85℃ | |||
| SN65LBC184PE4 Texas Instruments | 131 ₽ | ||
| SN65LBC184PE4 Texas Instruments | 179 ₽ | ||
| SN65LBC184PE4NOPBTI Texas Instruments | по запросу | ||
| SN65LBC184PE4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | 65LBC184 |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Common Mode Range | -7 to 12 |
| Duplex | Half |
| Fail Safe | Open |
| Fault Protection | -15 to 15 В |
| HBM ESD | 15 kV |
| ICC(Max) | 25 мА |
| IEC 61000-4-2 Contact | 30 +/- kV |
| Isolated | No |
| No. of RX | 1 |
| No. of TX | 1 |
| Number of Nodes | 128 |
| Package Group | PDIP |
| Rating | Catalog |
| Signaling Rate(Max) | 0.25 Mbps |
| Supply Voltage(s)(Nom) | 5 В |
| Бессвинцовая технология (Pb Free) | Да |
- RS-485 at 230-kbps Over Uncontrolled InterconnectPDF, 408 Кб, Файл опубликован: 12 апр 2004
This application report presents an evaluation of the SN65LBC184, SN65HVD22, and MAX487 transceivers in an uncontrolled impedance interconnection signaling at 230 kbps. The network used for the evaluation was identified as typical of that for building security. - RS-485 for Digital Motor Control ApplicationsPDF, 180 Кб, Файл опубликован: 12 май 2003
This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as - RS-485 for E-Meter Applications (Rev. A)PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs. - The RS-485 Unit Load and Maximum Number of Bus ConnectionsPDF, 197 Кб, Файл опубликован: 15 мар 2004
The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
Серия: SN65LBC184 (7)
- HPA00893P SN65LBC184D SN65LBC184DG4 SN65LBC184DR SN65LBC184DRG4 SN65LBC184P SN65LBC184PE4
- Semiconductors > Interface > RS-485/RS-422
