Datasheet Texas Instruments TL750L05CKTER — Даташит
СерияTL750L05
МодельTL750L05CKTER
Pin3
Package TypeKTE
Industry STD TermPFM
JEDEC CodeR-PSFM-G
МаркировкаTL750L05C
Width (мм)8
Length (мм)9.4
Thickness (мм)1.91
Pitch (мм)2.54
Max Height (мм)2.03
Accuracy(%)4
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.20 | 1ku
Fixed Output Options(V)5
Iout(Max)(A)0.15
Iq(Typ)(mA)1
Noise(uVrms)500
Operating Temperature Range(C)0 to 125
Output Capacitor TypeCap Free
Non-Ceramic
Output OptionsFixed Output
Package GroupDDPAK/TO-263
SOIC
TO-220
TO-252
TO-92
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
See datasheet (PDIP)
See datasheet (PFM)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)6
Vout(Max)(V)5
Vout(Min)(V)5
RoHSНе совместим
  • Techniques for accurate PSRR measurements
    PDF, 1.9 Мб, Файл опубликован: 28 окт 2013
  • A Topical Index of TI Supply Voltage Supervisor (SVS) Application Notes
    PDF, 56 Кб, Файл опубликован: 15 июн 2015
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • LDO Performance Near Dropout
    PDF, 149 Кб, Файл опубликован: 8 окт 2010
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
  • Linear and Switching Voltage Regulator Fundamental Part 1
    PDF, 183 Кб, Файл опубликован: 21 мар 2007
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TL750L05CKTER
