Datasheet Texas Instruments DAC6571IDBVT — Даташит
СерияDAC6571
МодельDAC6571IDBVT
10-битный цифро-аналоговый преобразователь 6-SOT-23 от -40 до 105
+2.7 V to +5.5 V, I2C Interface, Voltage Output 10-Bit DAC datasheet
PDF, 726 Кб, Версия: B, Файл опубликован: 30 авг 2005
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаD671
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Code to Code Glitch(Typ)20 nV-sec
DAC ArchitectureString
DAC Channels1
Gain Error(Max)1.25 %FSR
INL(Max)2 +/-LSB
InterfaceI2C
Offset Error(Max)N/A %
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Power Consumption(Typ)160 mW
Reference: TypeExt
Разрешение10 Bits
Sample / Update Rate0.125 MSPS
Время установления9 µs
Special FeaturesN/A
Zero Code Error(Typ)20 мВ
  • Evaluation Modules & Boards: DAC6571EVM
    DAC6571 Evaluation Module
  • Small Dynamic Voltage Management Solution Based On TPS62300 High Frequency Buck
    PDF, 261 Кб, Файл опубликован: 18 авг 2004
    As cellular phones and other portable electronics become more complex, more power is consumed by both active and standby systems. Consequently, power management design for portable devices offers new challenges in core voltage, energy management, and battery lifetime.Hardware designers already have started to use advanced and highly integrated power management devices featuring core voltage sc
На английском языке: Datasheet Texas Instruments DAC6571IDBVT
