Линейка продуктов KEEN SIDE
Datasheet Texas Instruments OPA4134UA/2K5 — Даташит
СерияOPA4134
МодельOPA4134UA/2K5
Высокопроизводительные операционные усилители звука SoundPlus™ 14-SOIC от -40 до 85
OPAx134 SoundPlusв„ў High Performance Audio Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 28 окт 2015
Pin14
Package TypeD
Package QTY2500
МаркировкаOPA4134UA
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesBurr-Brownв„ў Audio
АрхитектураFET
CMRR(Min)86 дБ
CMRR(Typ)100 дБ
GBW(Typ)8 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)5 мА
Iq per channel(Typ)4 мА
Количество каналов4
Offset Drift(Typ)2 uV/C
Output Current(Typ)40 мА
Rail-to-RailNo
Slew Rate(Typ)20 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Tuning in Amplifiers
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA4134UA/2K5
