Datasheet Texas Instruments BQ24085DRCR — Даташит
СерияBQ24085
МодельBQ24085DRCR
750 мА ОДНОЧИПОВАЯ ИС ИС УПРАВЛЕНИЯ ЗАРЯДОМ Li-Ion/Li-Pol с терморегулированием 10-VSON от 0 до 125
bq2408x 750-mA Single-Chip Li-Ion and Li-Pol Charge Management IC With Thermal Regulation datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 30 дек 2015
38 предложений от 17 поставщиков
Микросхема Чип управления батареи, Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6.5V input, 4.2V/750mA charge, SON-10
BQ24085DRCR
105 ₽
BQ24085DRCR
105 ₽
Эиком
BQ24085DRCR
от 206 ₽
Hi-Tech Circuit Group
BQ24085DRCR
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаCDV
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(20 В
Battery Charge Voltage(Max)4.2 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)0.75 A
Control InterfaceStandalone (RC-Settable)
Control TopologyLinear
Number of Series Cells1
Operating Vin(Max)6.5 В
Operating Vin(Min)4.35 В
Package GroupVSON
Package Size: mm2:W x L10VSON: 9 mm2: 3 x 3(VSON) PKG
Special FeaturesIntegrated FET,Temp Monitoring (Thermistor Pin),Thermal Regulation
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24085EVM
    Battery Charger Evaluation Module
  • Achieving Different Charge Voltage for bq2408x
    PDF, 110 Кб, Файл опубликован: 29 апр 2009
    By changing standard 4.2-V charge voltage to 4.1 V or lower, rechargeable lithium-ion (Li-ion) battery cycle life can be extended at low temperature. For new chemistry such as LiFePO4 rechargeable battery, it requires 3.6-V charge voltage. All these new applications need a nonstandard charge voltage. This application report gives examples of using the 4.2-V bq24085 charger to achieve different cha
  • How to Achieve Power-Path Management Function for bq2408x (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 21 апр 2009
    This application report presents a simple external circuit for achieving a power-path management function while maintaining an overvoltage protection function and blocking reverse current for low-cost linear battery chargers such as the bq2408x . Brief design criteria and a trade-off study with test results are presented.
Серия: BQ24085 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24085DRCR
