Datasheet Texas Instruments LM3644YFFR — Даташит
Серия | LM3644 |
Модель | LM3644YFFR |
Драйвер светодиодной вспышки для камеры с источником тока 1,5 А, 12-DSBGA -40–85
LM3644 Dual 1.5-A Current Source Camera Flash LED Driver datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 8 сен 2016
![]() 25 предложений от 16 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами | |||
LM3644YFFR Texas Instruments | от 32 ₽ | ||
LM3644YFFR Texas Instruments | 74 ₽ | ||
LM3644YFFR | по запросу | ||
LM3644YFFR Texas Instruments | по запросу |
Pin | 12 |
Package Type | YFF |
Industry STD Term | DSBGA |
JEDEC Code | R-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 3644 |
Width (мм) | 1.16 |
Length (мм) | 2 |
Thickness (мм) | 1.6 |
Pitch (мм) | .4 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
Iout(Max) | 2.5 A |
Iq(Typ) | 0.3 мА |
LED | 2 |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rating | Catalog |
Special Features | I2C Control,LED Thermal Monitor,OVP,Over Current Protection,Synchronous Rectification |
Vin(Max) | 5.5 В |
Vin(Min) | 2.5 В |
- Evaluation Modules & Boards: LM3644EVM
Synchronous Boost Dual LED Flash Driver Evaluation Module W/ 1.5A High-Side Current Sources
- Using the LM3643/4/8 in an Inductorless and/or Simplified PCB Routing ConfiguratPDF, 216 Кб, Файл опубликован: 11 окт 2016
The LM3643, LM3644 and LM3648 are a family of high power LED flash drivers that can be used as alighting source in many applications ranging from a mobile phones front facing selfie flash to a flash lighton a handheld point of sale (POS) terminal. While each device is highly configurable, there are timeswhere the full feature set might not be needed or where the fine pitch of the device (0 - Using Flash LED Drivers for Infrared (IR) LED ApplicationsPDF, 163 Кб, Файл опубликован: 20 мар 2017
The LM3643/4/8 devices are commonly used for mobile phone flash LED drivers. This application notediscusses the general applications of IR in mobile devices as well as the behavior of TI’s LM364X devicesfor such applications.These LED flash drivers are small solutions that provide a maximum of 1.5 A to one or two LEDs in eitherpass mode, where the current sources are connected to the input - LED Flash-Protection FeaturesPDF, 33 Кб, Файл опубликован: 23 авг 2017
Modern LED camera flash drivers are feature-rich and power dense. Capable of delivering over 2 A ofcurrent to dual LEDs in packages as small as 1.69 mm Г— 1.31 mm, flash LED drivers require built-in safetyand protection features to maintain long-term device and system health. Devices such as the LM3643,LM3644, LM3648, LM3646, LM3642, LM36010, and LM36011 all provide many specific protection
Серия: LM3644 (2)
- LM3644TTYFFR LM3644YFFR
- Semiconductors > Power Management > LED Driver > Strobe & Flash LED Driver
