Datasheet Texas Instruments UC2847DW — Даташит
СерияUC2847
МодельUC2847DW
ШИМ-контроллер текущего режима 16-SOIC от -40 до 85
UCx846/7 Current Mode PWM Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 4 янв 2016
Pin16
Package TypeDW
Package QTY40
МаркировкаUC2847DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)500 kHz
Gate Drive(Typ)0.5 A
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7.7/6.95 В
Vin(Max)40 В
Vin(Min)7.7 В
  • Modeling Analysis and Compensation of the Current-Mode Converter
    PDF, 189 Кб, Файл опубликован: 5 сен 1999
    As current-mode conversion increases in popularity several peculiarities associated with fixed-frequency peak-current detecting schemes have surfaced. These include instability above 50% duty cycle a tendency towards subharmonic oscillation non-ideal loop response and an increased sensitivity to noise. This application note attempts to show that the performance of any current-mode converter c
  • U-93 A New Integrated Circuit for Current Mode Control
    PDF, 411 Кб, Файл опубликован: 5 сен 1999
    Advantages of current-mode control over conventional PWM approaches to switching power converters include automatic feed-forward automatic symmetry correction inherent current-limiting simple loop-compensation enhanced load-response and the capability for parallel operation. This application note introduces the first control integrated circuit specifically designed for this topology defines
  • DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICs
    PDF, 27 Кб, Файл опубликован: 5 сен 1999
    The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806
Серия: UC2847 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC2847DW
