Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TS3A227EYFFR — Даташит
СерияTS3A227E
МодельTS3A227EYFFR
Автономный переключатель обнаружения и настройки аудиоаксессуаров 16-DSBGA от -40 до 85
TS3A227E Autonomous Audio Accessory Detection and Configuration Switch datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 5 фев 2015
Pin16
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
Маркировка227E
Thickness (мм).425
Pitch (мм).4
Max Height (мм).625
Additional FeaturesAccessory Type Detection Noise Reduction,Adjustable De-Bounce Timings,Autonomous Detection (3 or 4 poles),Click/Pop Noise Reduction,FM Transmission Capability,Integrated Codec Sense Line,Key Press Detection (up to 4 keys),Manual I2C Control,Manual Microphone Switch Control,Power Off Noise Removal
Configuration2 X SPDT
Input/Ouput Voltage(Max)4.5 В
Input/Ouput Voltage(Min)-3 В
Package GroupDSBGA
Ron(Typ)0.05 Ohms
VCC(Max)4.5 В
VCC(Min)2.5 В
  • Evaluation Modules & Boards: TS3A227E-EVM
    TS3A227E Evaluation Module
  • Support Selfie Sticks Using a TS3A227E Audio Jack Switch
    PDF, 229 Кб, Файл опубликован: 4 мар 2016
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3A227E (2)
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS3A227EYFFR
