Datasheet Texas Instruments TPS6755ID — Даташит
| Серия | TPS6755 |
| Модель | TPS6755ID |
Регулируемый инвертирующий DC/DC преобразователь 8-SOIC
Adjustable Inverting DC/DC Converter datasheet
PDF, 434 Кб, Версия: A, Файл опубликован: 1 дек 1996
Купить TPS6755ID на РадиоЛоцман.Цены — от 65 до 1 135 ₽39 предложений от 20 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — постоянного тока коммутирующие | |||
| TPS6755ID Texas Instruments | 371 ₽ | ||
| TPS6755ID | по запросу | ||
| TPS6755ID Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 75 |
| Carrier | TUBE |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
- TPS6755 Evaluation Using the TSP6735EVMPDF, 36 Кб, Файл опубликован: 23 май 2003
This application note describes how the TPS6755 can be evaluated using the TPS6735EVM. - Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS6755 (5)
- TPS6755ID TPS6755IDR TPS6755IDRG4 TPS6755IP TPS6755IPE4
- Semiconductors > Power Management > DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
