Datasheet Texas Instruments THS4304DGK — Даташит
СерияTHS4304
МодельTHS4304DGK
Широкополосный операционный усилитель 8-VSSOP от -40 до 85
THS4304: Wideband Operational Amplifier datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 30 июл 2004
26 предложений от 18 поставщиков
THS4304DGK
305 ₽
THS4304DGK
1 404 ₽
THS4304DGK
SUV System
THS4304DGK
Package TypeDGK
Industry STD TermVSSOP
Package QTY80
МаркировкаAKU
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic84 dBc
3rd Harmonic100 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl3000 МГц
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)3000 МГц
Input Bias Current(Max)12000000 pA
Iq per channel(Max)18.9 мА
Iq per channel(Typ)18 мА
Количество каналов1
Offset Drift(Typ)5 uV/C
Output Current(Typ)100 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)790 V/us
Total Supply Voltage(Max)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)6.4 нВ/rtГц
Vn at Flatband(Typ)2.4 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • Evaluation Modules & Boards: THS4304DGKEVM
    THS4304 Evaluation Module for DGK Package
  • Evaluation Modules & Boards: THS4304DBVEVM
    THS4304 Evaluation Module for DBV Package
  • RF and IF amplifiers with op amps
    PDF, 177 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS4304DGK
