Datasheet Texas Instruments TPS61121PW — Даташит
СерияTPS61121
МодельTPS61121PW
Повышающий преобразователь 3,3 В с КПД 95 % и LDO 1,5 В, 200 мА для одноэлементных литий-ионных или двухэлементных приложений 16-TSSOP от -40 до 85
TPS6112x Synchronous Boost Converter With 1.1-A Switch and Integrated LDO datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 28 май 2015
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаPS61121
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Duty Cycle(Max)100 %
Iq(Typ)0.04 мА
Package GroupTSSOP
Regulated Outputs2
Special FeaturesEnable,Light Load Efficiency,Load Disconnect,Power Good
Switch Current Limit(Min)1.1 A
Switch Current Limit(Typ)1.6 A
Switching Frequency(Max)600 kHz
Switching Frequency(Min)400 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: TPS61120EVM-205
    TPS61120 Evaluation Module
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61121 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61121PW
