Datasheet Texas Instruments TCI6638K2KBXAAW2 — Даташит
| Серия | TCI6638K2K |
| Модель | TCI6638K2KBXAAW2 |
Многоядерная однокристальная система DSP+ARM KeyStone II (SoC) 1517-FCBGA
TCI6638K2K Multicore DSP+ARMВ® KeyStone II System-on-Chip (SoC) datasheet
PDF, 2.2 Мб, Версия: F, Файл опубликован: 5 май 2017
| Pin | 1517 | 1517 |
| Package Type | AAW | AAW |
| Package QTY | 21 | 21 |
| Carrier | JEDEC TRAY (5+1) | JEDEC TRAY (5+1) |
| Маркировка | @2012 TI | TCI6638K2KXAAW |
| Width (мм) | 40 | 40 |
| Length (мм) | 40 | 40 |
| Thickness (мм) | 3.07 | 3.07 |
- Evaluation Modules & Boards: TCIEVMK2X
TCI6636K2H Evaluation Module
- Ethernet Packet Transfer Via FastC&M over AIF2 Application ReportPDF, 168 Кб, Файл опубликован: 6 дек 2013
- KeyStone I-to-KeyStone II Migration Guide (Rev. A)PDF, 479 Кб, Версия: A, Файл опубликован: 30 июл 2015
This guide describes the main System-on-Chip (SoC) level and peripheral changes that need to be considered when migrating a KeyStone I-based system design to a KeyStone II-based system design.In this guide, KeyStone I includes all TMS320TCI661x devices and KeyStone II includes all TCI663xK2y devices. Any differences within KeyStone I or KeyStone II devices are described explicitly.Keystone II DDR3 InitializationPDF, 73 Кб, Файл опубликован: 26 янв 2015
This application report provides a step-to-step initialization guide for the Keystone II device DDR3 SDRAM controller.Throughput Performance Guide for KeyStone II Devices (Rev. B)PDF, 866 Кб, Версия: B, Файл опубликован: 22 дек 2015
This application report analyzes various performance measurements of the KeyStone II family of processors. It provides a throughput analysis of the various support peripherals to different end-points and memory access.Keystone II DDR3 Debug GuidePDF, 143 Кб, Файл опубликован: 16 окт 2015
This guide provides tools for use when debugging a failing DDR3 interface on a KeyStone II device.Power Management of KS2 Device (Rev. C)PDF, 61 Кб, Версия: C, Файл опубликован: 15 июл 2016
This application report lists the steps to enable Class 0 Temperature Compensation (Class 0 TC) mode of SmartReflexв„ў Subsystem (SRSS) module available on such devices.Hardware Design Guide for KeyStone II DevicesPDF, 1.8 Мб, Файл опубликован: 24 мар 2014SERDES Link Commissioning on KeyStone I and II DevicesPDF, 138 Кб, Файл опубликован: 13 апр 2016
The serializer-deserializer (SerDes) performs serial-to-parallel conversions on data received from a peripheral device and parallel-to-serial conversion on data received from the CPU. This application report explains the SerDes transmit and receive parameters tuning, tools and some debug techniques for TI Keystone I and Keystone II devices.PCIe Use Cases for KeyStone DevicesPDF, 320 Кб, Файл опубликован: 13 дек 2011The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROMClocking Design Guide for KeyStone DevicesPDF, 1.5 Мб, Файл опубликован: 9 ноя 2010Optimizing Loops on the C66x DSPPDF, 585 Кб, Файл опубликован: 9 ноя 2010DDR3 Design Requirements for KeyStone Devices (Rev. B)PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014Multicore Programming Guide (Rev. B)PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicoreМодельный ряд
Серия: TCI6638K2K (1)- TCI6638K2KBXAAW2
- Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TCI6638K2KBXAAW2
