Datasheet ТI ADS1240E/1KG4 — Даташит
| Серия | ADS1240 |
| Модель | ADS1240E/1KG4 |
24-битный аналого-цифровой преобразователь 24-SSOP от -40 до 85
24-Bit, Analog-to-Digital Converters datasheet
PDF, 1.0 Мб, Версия: F, Файл опубликован: 8 окт 2013
- The Offset DAC (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 1 апр 2015
- ADS1240, 1241 App-Note: Accessing the Onboard Temp Diode in the ADS1240/ADS1241PDF, 65 Кб, Файл опубликован: 4 окт 2002
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Implementing a Direct Thermocouple Interface With MSP430x4xx and ADS1240 (Rev. A)PDF, 195 Кб, Версия: A, Файл опубликован: 4 окт 2001
This application report describes and shows how to implement a direct thermocouple interface, without using the signal conditioning circuitry normally required for thermocouples. The thermocouple interfaces directly to the Burr Brown ADS1240, 24-bit ADC from Texas Instruments, Inc. An MSP430F41x ultralow-power microcontroller is used to communicate with the ADC, read the conversion values, convert - Measuring Single-Ended 0V-5V Signals with Differential Delta-Sigma ADCs (Rev. A)PDF, 48 Кб, Версия: A, Файл опубликован: 18 май 2015
- Digital Filter Types in Delta-Sigma ADCsPDF, 219 Кб, Файл опубликован: 27 июн 2017
This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide - Overclocking the ADS1240 and ADS1241 (Rev. A)PDF, 73 Кб, Версия: A, Файл опубликован: 8 июл 2004
The ADS1240 and ADS1241 are precision, wide dynamic range, delta-sigma (О”ОЈ) Analog-to-Digital converters (ADCs) with 24-bit resolution. This application report describes the process of overclocking these low speed and low current consumption devices, allowing them to run considerably faster while maintaining performance at the expense of current consumption. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- Inputs Currents for High-Resolution ADCsPDF, 127 Кб, Файл опубликован: 6 мар 2003
Серия: ADS1240 (4)
- ADS1240E ADS1240E/1K ADS1240E/1KG4 ADS1240EG4
