Datasheet Texas Instruments SN74AUC2G02YZPR — Даташит
СерияSN74AUC2G02
МодельSN74AUC2G02YZPR
ДВОЙНОЙ 2-ВХОДНОЙ ПОЛОЖИТЕЛЬНЫЙ-НИ-ГЭТ 8-DSBGA от -40 до 85
SN74AUC2G02 datasheet
PDF, 942 Кб, Версия: C, Файл опубликован: 11 янв 2007
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаUBN
Width (мм)2.25
Length (мм)1.25
Thickness (мм).31
Pitch (мм).5
Max Height (мм).5
3-State OutputNo
Bits2
F @ Nom Voltage(Max)250 Mhz
Gate TypeNOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupDSBGA
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNOR Gate
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)8,3.5,2.2,1.8,1.3 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G02YZPR
