Datasheet Texas Instruments ADS8413IRGZRG4 — Даташит
СерияADS8413
МодельADS8413IRGZRG4
16-разрядный униполярный дифференциальный вход, частота дискретизации 2 MSPS, АЦП от 4,75 до 5,25 В с последовательным интерфейсом LVDS 48-VQFN от -40 до 85
16-Bit, 2-MSPS, LVDS Serial Interface, SAR ADC datasheet
PDF, 1.6 Мб, Файл опубликован: 6 окт 2005
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
# Input Channels1
Analog Voltage AVDD(Max)(V)5.25
Analog Voltage AVDD(Min)(V)4.75
Approx. Price (US$)21.35 | 1ku
АрхитектураSAR
Digital Supply(Max)(V)5.25
Digital Supply(Min)(V)2.7
INL(Max)(+/-LSB)2
Input Range(Max)(V)4.096
Тип входаDifferential
Integrated FeaturesDaisy-Chainable
Oscillator
InterfaceParallel
Multi-Channel ConfigurationN/A
Operating Temperature Range(C)-40 to 85
Package GroupVQFN
Package Size: mm2:W x L (PKG)48VQFN: 49 mm2: 7 x 7(VQFN)
Power Consumption(Typ)(mW)155
Reference ModeExt
Int
Resolution(Bits)16
SINAD(dB)92
SNR(dB)92
Sample Rate (max)(SPS)2MSPS
THD(Typ)(dB)-107
RoHSНе совместим
  • Connecting ADS8410/13 With Long Cable
    PDF, 773 Кб, Файл опубликован: 2 дек 2005
    Many applications require that the analog-to-digital converter (ADC) be located near the field sensor; however, the digital processing often occurs at a distance. Therefore, the input and output signals need to travel through a long cable from the field sensor to the site where digital processing occurs. This application report is a guide for using a 1-meter cable, the Samtec EQCD Series high data
  • Using ADS8410/13 in Daisy Chain Mode
    PDF, 3.2 Мб, Файл опубликован: 22 май 2006
    Many applications require multiple analog-to-digital converters (ADC) in a system. Daisy chaining multiple ADCs enables the use of a single data receiver or a small FPGA. It offers easy and minimal digital routing. This application report describes how multiple ADCs (ADS8410/13) work in a daisy-chain mode. The device offers a high-speed (200 Mbps) LVDS serial interface. This application report als
  • Using ADS8410/13 in Cascade Mode
    PDF, 2.9 Мб, Файл опубликован: 8 июн 2006
    Many applications require multiple analog-to-digital converters (ADC) in a system. Cascading multiple ADCs enables the use of a single data receiver or a small FPGA. This offers lower power consumption and independent ADC usage. This application report describes how multiple ADCs (ADS8410/13) work in a cascade mode. The ADS8410/13 integrated circuit offers a high-speed (200 Mbps) LVDS serial inter
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments ADS8413IRGZRG4
