Datasheet ТI LMS1585ACSX-3.3/NOPB — Даташит
| Серия | LMS1585A |
| Модель | LMS1585ACSX-3.3/NOPB |
Линейные регуляторы с фиксированным/регулируемым выходом 5 А / LDO 3-DDPAK/TO-263 от 0 до 125
LMS1585A/LMS1587 5A and 3A Low Dropout Fast Response Regulators datasheet
PDF, 1.7 Мб, Версия: G, Файл опубликован: 18 июл 2013
- A Topical Index of TI LDO Application Notes (Rev. F)PDF, 82 Кб, Версия: F, Файл опубликован: 27 июн 2019
- Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
- Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet. - Linear power for automated industrial systemsPDF, 1.8 Мб, Файл опубликован: 9 янв 2015
Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a - AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
This application note discusses the operation and compensation of linear regulators. - AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t - Understanding the Terms and Definitions of LDO Voltage RegulatorsPDF, 197 Кб, Файл опубликован: 21 окт 1999
This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab - AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - Packaging Limits Range of Linear RegulatorsPDF, 75 Кб, Файл опубликован: 8 май 2010
The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LMS1585A (16)
LMS1585ACSX3.3/NOPB, LMS1585ACSX 3.3/NOPB
